create routine load test.test1 on test1
columns (app_id,app_name,description,cookie_domain,cookie_path,index_url,verify_name, database,temp,__op=(CASE temp WHEN “DELETE” THEN 1 ELSE 0 END) )
“format”=“json”,
“jsonpaths” = “[”$.data[0].app_id","$.data[0].app_name","$.data[0].description","$.data[0].cookie_domain","$.data[0].cookie_path","$.data[0].index_url","$.data[0].index_url","$.data[0].verify_name" ,"$.database","$.type" ]",
“desired_concurrent_number”=“1”,
“max_error_number”=“0”
FROM KAFKA (
“kafka_broker_list”= “10.0.10.12:9092”,
“kafka_topic”=“test_test1”
“jsonpaths” = “[”$.data[0].app_id","$.data[0].app_name","$.data[0].description","$.data[0].cookie_domain","$.data[0].cookie_path","$.data[0].index_url","$.data[0].index_url","$.data[0].verify_name" ,"$.database", “$.type” ]",
如果canal json过来的 data节点数据是多条,比如:“data”: [
“app_id”: “12312”,
“app_name”: “12312323423”,
“description”: “12312123”,
“cookie_domain”: “1231”,
“cookie_path”: “231”,
“index_url”: “23123”,
“verify_name”: “1231231”
“app_id”: “12312”,
“app_name”: “4444444”,
“database”: “test”,
“es”: 1647346751000,
“id”: 4241,
“isDdl”: false,
“mysqlType”: {
“app_id”: “varchar(10)”,
“app_name”: “varchar(50)”,
“description”: “varchar(100)”,
“cookie_domain”: “varchar(64)”,
“cookie_path”: “varchar(400)”,
“index_url”: “varchar(400)”,
“verify_name”: “varchar(64)”
“old”: [
“app_name”: “123123”
“pkNames”: [
“app_id”
“sql”: “”,
“sqlType”: {
“app_id”: 12,
“app_name”: 12,
“description”: 12,
“cookie_domain”: 12,
“cookie_path”: 12,
“index_url”: 12,
“verify_name”: 12
“table”: “test1”,
“ts”: 1647346751924,
“type”: “UPDATE”
如何设置这个jsonpath ?
当时不支持data中是一个array的数据格式
当时不支持? 现在支持了吗?
现在不支持data中是一个array格式
发下routine load配置
是的,当前不支持json path和json root同时指定,咱们可以使用flink-cdc的方案吗?可以读取kafka中canal的数据然后同步到starrocks
请问有没有flink-cdc 和kafka的完整列子?
本来表就多,如果在引入flink-cdc感觉不好维护,是否稳定可靠?
flink-cdc 会锁表,flink-sql生成 job 异常中断后无法恢复,表一多,表结构变更多的场景下维护很麻烦
你们在数据同步这块没可靠稳定的易维护的方案吗?
可参考https://forum.mirrorship.cn/t/topic/1815
请问下这个json path和json root同时指定的问题,以后版本会修复嘛,如果会的话,大概是什么版本,现在我遇到是2.1版本貌似都有这个问题,2.0貌似不会
